MGCP Config not showing endpoints
StrikerTS84
Hi All,
I'm in the process of migrating, with a new server setup using CUCM 7, to a 3845 gateway from out 2821. I'm having trouble getting the VWIC2-1MFT-T1E1 to register with the CUCM server. Also, and more perplexing to me, when I run a "sho mgcp end" both our interfaces don't have any endpoints listed. To my knowledge I have everything configured properly on the CUCM server. I'm also using "dial-peer voice 1 pots" the service is set to "MGCPAPP" and the port is using "controller t1 0/0/0."
I'm out if ideas at this point. Anyone have any? I have run "no mgcp" - "mgcp" a few times now.
Jon Marshall
Trevor
No offense intended but to get an answer to your question you would be better off posting this thread into the IP telephony forum where you are far more likely to get the help you need -
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Ddisplay_messages%26mode%3Dnew%26location%3D.ee6c829
Jon
Thanks for the reply! I was actually not 100% sure myself.
