mgmt interface on the 3750x connected to ASA
talalaec02585
Hello everyone! There is a small network, a Cisco ASA 5515-x edge device and two Cisco 3750-x switches.
 icmp allowed on the ASA. Switch (1/0/48) connected to GigabitEthernet0/1 device ASA. The PC connected to the port 1/0/1 Switch1 is ping successfully from ASA. The management interface (vlan101) on the switch does no ping from ASA. The switch doesn't have any access list.
What could be the problem?
asa config
 interface GigabitEthernet0/0
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.252
interface GigabitEthernet0/1
no nameif
no security-level
no ip address
interface GigabitEthernet0/1.99
vlan 99
nameif lan
security-level 100
ip address 10.60.60.1 255.255.254.0
interface GigabitEthernet0/1.101
vlan 101
nameif mgmt
security-level 100
ip address 10.255.255.1 255.255.255.0
same-security-traffic permit inter-interface
SWITCH1
interface GigabitEthernet1/0/1
switchport access vlan 99
switchport mode access
interface GigabitEthernet1/0/48
switchport trunk native vlan 101
switchport mode trunk
interface Vlan1
no ip address
shutdown
interface Vlan101
ip address 10.255.255.2 255.255.255.0
ip default-gateway 10.255.255.1
Hello
you have native vlan 101 in the switchport tunk however the sub-interface on the asa .101 isn’t native it’s tagged to vlan 101 so change the native vlan to 1 on the switchport and you should gain connection
Kind Regards
Paul
Hello
Kind Regards
Paul
yes it did help. thanks a lot
