Hello.
I have setup MHSRP on two core 3750 and conncted a switch going to both as POC
But when i shutdown the link or bring back up the link between 2950-LAB and 3750-13 I completely lose connection to 3750-13 even from 3750-12 for about 30 seconds then it comes back and re-routes
Does the same on the other way around if i disable the port between 3750-12
What im trying to achive is the CORE's 3750-12 and 3750-13 to be redundate as cores and have my access switch in this case 2950-lab to be redundandt which will go to both
I just dont undertand why it would cause a core switch to timeout completly from everything.
