Migrating Config: Config Replace Command Problem
csmiler
Community Member
How can I remotely change router configurations to a totally new configuration file BUT have the ability to return to my original configurations without having someone at the sites. Currently have a network full of routers. We need to migrate these configuration to new configurations. My concept was to use the config Replace command to replace the current running config with a newly FTPed config residing in flash. Before that, I would have invoked the Reload command to reload the router if the newly replaced config had any problems as a backout plan. If everything came back up, I would log back on and Reload Cancel.
PROBLEM:
When I use the Config Replace command, I get errors unless the configuration is very simular as if the command only works if there is not radical changes in the configurations. One of the errors is "Error: Could not write to output buffer incremental-temp.cfg" another error would simply be that it was rolling back.
The configuration files that I Ftped were created by the IOS so they are in the correct config replace format.
Does anyone have any idea how I can do massive configuration changes on remote routers BUT have the ability to return to original configuration if needed without human intervention from the remote site?
mchin345
Level 11
Level 11
Paste the output of the 'show tech' as well as a capture from the console when you attempt to run the 'config replace' command as well as a 'show log'
