minimum configurations needed for etherchannel
sarahr202
Level 5
Level 5
hi every body!
let say I have two switches ,sw1 and sw2
I want to use etherchannel
sw1(config) int f0/1
sw1(con-if)channel-group 1 mode desirable.
Assuming the sw2 has similar configuration in place, would the etherchannel form? or Do I need to use"channel-protocol pagp" command?
thanks a lot!
2 Accepted Solutions
Edison Ortiz
Yes.
It's not required. This command ensures that the only protocol acceptable in the etherchannel is PAgP.
For instance, if you were to configure active<->passive along with channel-protocol pagp, then the channel wouldn't form.
HTH,
__
Edison.
Jon Marshall
Sarah
For a layer 2 etherchannel you only need the config you supplied ie.
the port-channel interface is automatically created for you.
For L3 etherchannels you need to manually create the port-channel interface and then assign the ports into the corresponding channel-group.
Jon
Edison Ortiz
Yes.
HTH,
__
Edison.
Jon Marshall
Sarah
Jon
