Mirror all traffic to one port or use a network tap
I am about to setup an IDS on our network, I have two options - 1 is simply mirror all traffic through one port, 2 is to use a network trap. I am not a big fan of adding the network trap, I am OK with using port replication/mirroring as long as that should not cause too much overhead of the switch. Anyone tried this before ? Did the switch CPU consumption change ?
singhaam007
Level 3
Level 3
HI Ali,
A successful IDS deployment doesn't need heavy CPU horsepower. It does, however, need to be connected to the network properly and have enough storage to allow useful analysis of the data .
You can install the IDS via a span port on a switch, for example, or via a network tap. Each method has its advantages and disadvantages.
We tried it one our firewall but CPU was hitting 100 % most of the time so we end up upgrading the hardware.
Please check this link for more details.
http://www.networkcomputing.com/data-networking-management/setting-up-an-intrusion-detection-system/229620735?pgno=1
Please rate if this information is helpful.
thanks
