mLACP vs LACP at stacked/VSS switches
Dears
Would like your advice plz regarding the difference between mLACP vs LACP on stacked/VSS switches
I believe technically it is the same.
What I know that on stacked switches, all switches have same configuration as they are considered one device
Is this valid also with mLACP ?
If yes then what is the difference ???
Many Thanks
BR,
Sherif Ismail
Reza Sharifi
Sherif,
Here is some info on mLACP.  This is a new feature with a lots of restrictions:
http://www.cisco.com/en/US/docs/ios-xml/ios/cether/configuration/15-1s/ce-multichass-lacp.html#GUID-04AE1391-0A2E-405A-B60E-FABBE556E729
Thanks Reza
After some readings I concluded below
VSS supported only at 6500
Stacking  supported on catalyst switches
mLACP is only available at 7600 as it does not support VSS or stacking.
I also believe (however still not confirmed) when configuring mLACP, each 7600 router still has its own configuration
i.e config on both routers are not identical as in VSS/Stacking
BR,
Sherif Ismail
