Modbus TCP
rongolsen
Are there special software tools \hardware that can detect and route ModbusTCP packets more efficiant?
wong34539
Level 6
Level 6
Modbus/TCP is an open automation protocol used in a variety of SCADA, PLC, and industrial IO applications. Modbusfw is a Linux 2.4.x Netfilter Extension that permits filtering decisions (DROP, REJECT, etc.) based on application-layer values, allowing finer-grained access control than is currently possible by simply blocking TCP port 502
http://modbusfw.sourceforge.net/
andrew.burns
Level 7
Level 7
You might want to look at implementing some kind of QoS, marking modbus packets on entry to the network and prioritising them as they pass through.
Here's a link to some white papers which should give you some ideas:
http://www.cisco.com/en/US/products/ps6558/prod_white_papers_list.html
Andrew.
