Modify priority of a packet (TCP) for a given ip
shyamsundarn6
How do I modify the priority of a TCP packet for a given source ip?
I mean how do I modify the priority of a TCP packet transmitted from a given ip address say 192.168.10.3?
7 Replies 7
amabdelh
You need to use qos, and in your class map us an access-list that match this particular source/port
I am already defining access list for various ips in the same vlan
So assigning priority for an access-list makes it applied to all the ips.
I cannot use an access-list for just 1 ip.
So I have given many ips for a given access-list.
However, I want to modify the priority for the packet coming from only one pc in that access-list, not all pcs in that access-list.
How do I modify the priority for that given ip's packets alone?
Can u post your configuration
Amjad Abdelhalim
Current configuration : 1550 bytes
version 15.0
hostname sap
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
license udi pid CISCO1841 sn FHK144570UZ
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.10.1 255.255.255.0
ip access-group 101 in
ip access-group 102 out
ip summary-address eigrp 1 192.168.10.0 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 192.168.15.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 192.168.4.10 255.255.255.252
clock rate 64000
interface Serial0/0/1
no ip address
clock rate 64000
router eigrp 1
network 192.168.10.0
network 192.168.15.0
neighbor 192.168.10.3 FastEthernet0/0.1
neighbor 192.168.10.4 FastEthernet0/0.1
neighbor 192.168.15.3 FastEthernet0/0.2
router rip
network 192.168.4.0
network 192.168.5.0
ip forward-protocol nd
no ip http server
access-list 101 permit tcp host 192.168.10.3 host 192.168.15.3
access-list 101 permit tcp host 192.168.10.4 host 192.168.15.3
access-list 102 permit tcp host 192.168.15.3 host 192.168.10.3
access-list 102 permit tcp host 192.168.15.3 host 192.168.10.4
control-plane
line con 0
line aux 0
line vty 0 4
login
length 0
scheduler allocate 20000 1000
end
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You could use a CBWFQ policy-map to tag on input.
e.g. something like
access-list 100 permit tcp host 192.168.10.3 any
access-list 100 permit tcp host 192.168.10.30 any
class-map match-any tagCS3
match access-group 100
policy-map tag
class tagCS3
set ip dscp cs3
interface x
service-policy in tag
Hi Joseph,
I have more than one pc connected in the same interface.
I do no want all pc to have the sqame priority.
I want to specify the priority for a given ip in an interface.
Pls help me asap.
Disclaimer
Posting
You can extend the sample policy I posted with multiple classes.  Could be one, or more, host match per tagging.  You should run out of tags before you run out of classes.
