Module GBIC SFP in 2960
lordeon85
hello,
i want to install a module GBIC SFP for multimode fx in switch 2960, i bought the module type MFEFX1, but when i put it in the 2960, nothing.
Is it a good module?
if it isn't the good, what type of model i have to buy for my lan access by optical fiber.
if it's good why it doesn't light?
thanks a lot for your answer
Leo Laohoo
Who manufactured the SFP? If it ain't Cisco, you can't use it. A software in the software will interrogate the module and if it doesn't have the microcode, the appliance will disable the port.
Cisco SFP Optics For Gigabit Ethernet Applications
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6577/product_data_sheet0900aecd8033f885.html
nsn-amagruder
Level 5
Level 5
What is the exact part number of the gbic? I can tell you that inserting gbics into the 2960 can be a challenge. They don't always snap in the 1st, 2nd or 3rd time.
If it pulls out easily, it wasn't inserted. Pull it out and push it in with a little force. The clip on the bottom of the gbic will be all the way down and not half way up.
Aaron Magruder
NonStop Networks
