modules vs interface
karthick raja
Community Member
can any one explain me , what is the differenece between modules vs interface vs slots
Peter Paluch
An interface is a particular port that provides a network communication capability. Physically, it is a socket into which you can plug an appropriate cable - Ethernet cable, phone cable for DSL connection, coaxial cable for CATV, serial cable for diverse WAN technologies, ISDN cables, etc.
A module is a pluggable card that you can insert into a router that contains the circuitry to provide you with one or more interfaces of the same kind. In other words, a module carries one or more interfaces and allows you to extend the connectivity of your router according to your needs.
Check out the following picture taken from the Cisco's document:
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/datasheet_c78-491363.html
http://www.cisco.com/en/US/partner/prod/collateral/modules/ps5949/images/datasheet_c78-491363-1.jpg
What you see here are two modules. The HWIC-1DSU-T1 has one T1 interface, the HWIC-2T has two serial interfaces (you can see one or two connectors on the faceplate).
A slot is the empty space in the router into which a module can be inserted. In other words, it is the socket into which you insert module cards. Different router models have different numbers of slots so smaller routers have, say, two slots (i.e. you can insert at most two modules into them) while bigger routers can have 4 or even 8 slots to be populated by modules.
Best regards,
Peter
Peter Thank you  for your quick turnaround time. it's clear now
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
NB: (I know Peter knows this, but for others who might not . . .) Most often modules do provide interfaces of the same kind, but there are exceptions (i.e. where all interfaces are not exactly alike).  Also, some modules provide features not related to interfaces (e.g. 6500 service modules).  Also some cards that can be placed into slots themselves take modules or smaller cards.
