monitor a specific port
Mero Cisco
Level 3
Level 3
Dear all,
For the debugging purpose I need to save every communication from and to an ip address 10.10.10.20 connected to a cisco manageable switch. This pc is connected to fa0/10. For better debugging purpose I need the communication to a port no 675 only. How to get and save this communication to a file?
Waiting for your response,
Mero
use SPAN to mirror all traffic from to this port where the machine is located then on the machine connected to destination SPAN port use  a capture filter for wireshark to only capture what you need.
Alain
Parvesh Paliwal
Level 6
Level 6
You can go for a network tap .... and capture the traffic as you want.
Alain
