Monitoring Active Calls via SNMP on Cisco 4400 series gateways
greg.massaccesi
For a number of our gateways we are using snmp to monitor Active Calls; however, we are in the process of upgrading some of the gateways to the ISR 4400 series.  On the older gateways we were using CISCO-POP-MGMT-MIB, but that doesn't seem to exist on the ISR 4400 series.
Ideally we would want to monitor specific interfaces as opposed to total calls.  Does someone know of an equivalent MIB for the ISR 4400 series of gateways?
Previously used:
  • MIB: CISCO-POP-MGMT-MIB
  • OID: 1.3.6.1.4.1.9.10.19.1.1.9.1.3.0.0
Thank you.
s_zinafi
Hi , I am facing  the same issue , we have a series of ISR 4400 and I am looking for the OID of  active calls , has any managed to get this sorted ?
