monitoring network vs application
carl_townshend
Hi all, when I want to make sure that a problem is the server, not the network, do I monitor the repsonse time to the server againts the network, or do you monitor the application somehow? whats the best tool foor this ?
cheers
carl_townshend
can anyone help on this?
thanks
There is a Network Management Forum next to us.
Try there 🙂
Cristian
The best way would be to use a NMS wherein you can add devices with their service. Which will monitor all the devices and their services and in case of any outage sends alerts to the administrator.
Try out the NMS at the following link:
http://www.mikrotik.com/download/dude-install-3.0beta3.exe
Hope this helps...
AbhisheK
Please rate helpful posts!!!
