05-18-2013 07:09 PM - edited 03-07-2019 01:26 PM
As the title states, what is a good IOS version to stick on a 3750 (normal, no X or G series) switch? This is being used for a Cisco Lab in my CCNP - SWITCH studies.
Normaly I referance INE's site though they dont have a 3750 (only 3560) IOS recomendations.
Solved! Go to Solution.
05-18-2013 07:48 PM
IP second Reza's recommendation, 12.2(55)SE7 is, currently, THE most stable IOS around.
If you need 15.0, then you can try 15.0(2)SE2.
05-18-2013 07:26 PM
122-55 is the latest on Cisco.com and seems to be pretty stable..
c3750-ipbasek9-mz.122-55.SE7.bin
05-18-2013 07:48 PM
05-18-2013 09:55 PM
Thank you for that information, I will upgrade to that revision. I don’t believe my model however supports IOS 15 code, at least I don’t see it on Cisco's download page for the switch "Cisco Catalyst 3750-24TS" or would installing the 15x code from say 3750-X model theoretically work (non-production of course).
05-18-2013 10:01 PM
leolaohoo,
you answered my question about the v15 on normal 3750 via https://supportforums.cisco.com/thread/2096079.
Thanks Again!
05-18-2013 10:10 PM
Glad to be of some form of assistance.
Thanks for taking the time to rate our posts.
05-18-2013 10:01 PM
If your applliance has 16 mb flash, then the highest version is 12.2(55)SE and later (like SE7).
If your appliance has 32 mb flash, then you can go as high as 15.0(2)SE and later (like SE2).
