MQC to MLS QOS conversion tool
Pavel Bykov
Level 5
Level 5
Hi there. Since my previous QoS Calculator, which allowed you to configure queue sizes on Sasquatch-based switches (e.g. from 2960 to 3750-X), there have been many requests for configuration simplification. I created a basic tool that allows you to enter configuration just as you would with MQC: parent policy, child policy, shape average, bandwidth kbps... And based on entered information the tool generates MLS QOS configuration that you can then paste into a switch.
The tool is here: http://www.boxoid.org/bitsonwire/?p=142
This is a simple tool, which does not allow threshold use. I might create an advanced tool that will allow for threshold manipulation in a manner similar to MQC on ME3400, depending if you'll find it useful or not.
P.S.: I wrote it without syntax check, so a typo can be expected here and there
manuel.celesia
Hi Pavlo, could you send me this tool? my mail is manuelcelesia@gmail.com . thanks.
Even better, I'm attaching the spreadsheet here
