cisco 6500 power to module in slot 1 set off (FRU-power failed)
Cisco_CoE .
Hi guys,
Can u please help on these.
00:01:32: %C6KPWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
00:01:35: %OIR-SP-6-PWRFAILURE: Module 1 is being disabled due to power convertor failure. PMB registers are dumped as follows, R0= 0x2, R1= 0x2, R2= 0x0, R3= 0x0, R4= 0x0, R5= 0x0, R6= 0x0, R7= 0x0, R8= 0x0, R9= 0x0, R10= 0x0, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x0, R15= 0x0
00:01:35: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (FRU-power failed)
Router#sh mod
Mod Ports Card Type Model Serial No.
1 8 Intrusion Detection System WS-SVC-IDSM-2 SAD140203BL
3 8 Intrusion Detection System WS-SVC-IDSM-2 SAD140203AT
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL10382055
Mod MAC addresses Hw Fw Sw Status
1 0023.ebe6.c788 to 0023.ebe6.c78f 6.5 7.2(1) 7.0(6)E4 Ok
3 0023.ebe6.c7d8 to 0023.ebe6.c7df 6.5 7.2(1) 20.1(1)SXI8 Other
5 0016.9df6.a148 to 0016.9df6.a14b 5.3 8.5(4) 12.2(33)SXI8 Ok
Mod Sub-Module Model Serial Hw Status
1 IDS 2 accelerator board WS-SVC-IDSUPG 71093240028 2.5 Ok
5 Policy Feature Card 3 WS-F6K-PFC3B SAL10360MVD 2.5 Ok
5 MSFC3 Daughterboard WS-SUP720 SAD082504EP 2.11 Ok
Mod Online Diag Status
1 Pass
3 Unknown
5 Pass
7 Replies 7
Leo Laohoo
Doesn't make sense.  The log above tells me the line card in slot 1 is dead but the output in "sh module" shows an IDSM in slot 1 to be working, HOWEVER, the IDSM in slot 3 is either booting up or not powering up properly.
Hi Leo,
Problem is IDS is getting rebooting continuously. Observed same when inserted to other slots too. Same type card is working in other slot.
Here is more details.
Router#[Ash mod
2 8 Intrusion Detection System WS-SVC-IDSM-2 SAD140203AT
3 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL1537PPNL
2 0023.ebe6.c7d8 to 0023.ebe6.c7df 6.5 7.2(1) 20.1(1)SXI8 Other
3 7081.058e.d7ec to 7081.058e.d7ef 3.2 12.2(14r)S5 12.2(33)SXI8 Ok
00:16:34: %OIR-SP-6-PWRFAILURE: Module 2 is being disabled due to power convertor failure. PMB registers are dumped as follows, R0= 0x2, R1= 0x2, R2= 0x0, R3= 0x0, R4= 0x0, R5= 0x0, R6= 0x0, R7= 0x0, R8= 0x0, R9= 0x0, R10= 0x0, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x0, R15= 0x0
00:16:34: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (FRU-power failed)  1 Pass
00:17:02: %OIR-SP-6-PWRFAILURE: Module 2 is being disabled due to power convertor failure. PMB registers are dumped as follows, R0= 0x2, R1= 0x2, R2= 0x0, R3= 0x0, R4= 0x0, R5= 0x0, R6= 0x0, R7= 0x0, R8= 0x0, R9= 0x0, R10= 0x0, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x0, R15= 0x0
00:17:02: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (FRU-power failed)
00:17:30: %OIR-SP-6-PWRFAILURE: Module 2 is being disabled due to power convertor failure. PMB registers are dumped as follows, R0= 0x2, R1= 0x2, R2= 0x0, R3= 0x0, R4= 0x0, R5= 0x0, R6= 0x0, R7= 0x0, R8= 0x0, R9= 0x0, R10= 0x0, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x0, R15= 0x0
00:17:30: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (FRU-power failed)sh mod
Router#sh mod
2 0023.ebe6.c7d8 to 0023.ebe6.c7df 6.5 7.2(1) 20.1(1)SXI8 PwrDown
1 Pass
2 Unknown
5 Pass
find the log attached
Ok, the alarm logs are starting to make sense (to me) and ... you're not going to like what I'm about to say.
Sadly, if there's a problem with one slot, then I'd blame the line card.  However, I'm now seeing a problem with TWO (2) slots.  This is unheard of if not very rare.  I believe you'll need to contact TAC to get the chassis replaced.
Hi Leo,
Thanks for the quick response.
Kindly confirm two things
1. Have you checked the log i have attached ?
2.Is there is any clear evidence we can point out before going out for a chasis replacement.
Module 3 is being disabled due to power convertor failure.
Slot 2 is an IDSM.  Slot 3 is a 6704-10GE line card.  No way those two cards crashed by itself.  It's a failure with the backplane card.
I'm fairly certain it's an RMA of the chassis.
However, there is one way of testing this.  MOVE the IDSM & 6704 into different slots and see if the problem follows them to their new location or not.
Hi Leo,
Thanks  for the update.
Please note that module 3 got disabled only after i insert the IDS .
00:17:48: %OIR-SP-6-PWRFAILURE: Module 2 is being disabled due to power convertor failure. PMB registers are dumped as follows, R0= 0x2, R1= 0x2, R2= 0x0, R3= 0x0, R4= 0x0, R5= 0x1, R6= 0x0, R7= 0x0, R8= 0x0, R9= 0x0, R10= 0x0, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x0, R15= 0x0
00:17:48: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (FRU-power failed)
00:18:08: %OIR-SP-6-REMCARD: Card removed from slot 3, interfaces disabled
00:18:35: %OIR-SP-6-REMCARD: Card removed from slot 2, interfaces disabled
00:19:07: %OIR-SP-6-PWRFAILURE: Module 3 is being disabled due to power convertor failure. PMB registers are dumped as follows, R0= 0x2, R1= 0x2, R2= 0x0, R3= 0x0, R4= 0x0, R5= 0x0, R6= 0x0, R7= 0x0, R8= 0x0, R9= 0x0, R10= 0x0, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x0, R15= 0x0
00:19:07: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (FRU-power failed)
Router#sh mod
What I meant was move the IDSM & the 6704 away from slots 2 & 3.  Use other FREE slots.
