MST issue between cisco2950 and cisco4006
kangzhen
hi,
i configured mst among 2 cisco2950 and 1 cisco4006. i believed i typed in all required setting on them, but the mst seems works only on 2 2950, not 4006.
config on all 3 switch:
4006:
#MST (IEEE 802.1s)
set spantree priority 24576 mst 3
set spantree priority 24576 mst 5
#MST Configuration
set spantree mst config rollback force
set spantree mst config name abc revision 10
set spantree mst 0 vlan 1-102,107-4094
set spantree mst 3 vlan 103-104
set spantree mst 5 vlan 105-106
set spantree mst config commit
2950:
j2950#sh spanning-tree mst configuration
Name [abc]
Revision 10
Instance Vlans mapped
0 1-102,107-4094
3 103-104
5 105-106
based on the config, 4006 is supposed to be the root for instance 3 and 5. but somehow one 2950 worked as root for instance 3 and 5. even worse, 4006 is totally invisible for both 2950.
after enable the debug on 2950, some output looks like below: (fa0/1 connected to my 4006 and fa0/24 is to another 2950)
17:33:11: MST[0]: Fa0/1 ( designatedportid, fromMyregion 1)
17:33:11: MST(0): Fa0/1 rcvd info remaining 6
17:33:11: MST:BPDU DUMP [rcvd_bpdu Fa0/1 Repeated]
17:33:11: MST: Proto:0 Version:3 Type:2 Role: DesgFlags[ F ]
17:33:11: MST: Port_id:8414 cost:200000
17:33:11: MST: root_id :0001.4252.3549 Prio:32768
17:33:11: MST: br_id :0003.e316.e200 Prio:32768
17:33:11: MST: age:1 max_age:20 hello:2 fwdelay:15
17:33:11: MST: V3_len:116 PathCost:0 region:eds rev:10
17:33:11: MST: ist_m_id :0003.e316.e200 Prio:32768 Hops:20 Num Mrec: 2
17:33:11: MST[0]: Fa0/24 ( designatedportid, fromMyregion 1)
17:33:11: MST(0): Fa0/24 rcvd info remaining 6
17:33:11: MST:BPDU DUMP [rcvd_bpdu Fa0/24 Repeated]
17:33:11: MST: Proto:0 Version:3 Type:2 Role: DesgFlags[ FL ]
17:33:11: MST: Port_id:32770 cost:200000
17:33:11: MST: br_id :000c.8582.3800 Prio:32768
17:33:11: MST: V3_len:116 PathCost:200000 region:eds rev:10
17:33:11: MST: ist_m_id :0003.e316.e200 Prio:32768 Hops:19 Num Mrec: 2
17:33:11: MST: stci=3 Flags[ FL ] Hop:20 Role:Desg [Repeated]
17:33:11: MST: br_id:000c.8582.3800 Prio:32771 Port_id:32770 Cost:0
17:33:11: MST: stci=5 Flags[ FL ] Hop:20 Role:Desg [Repeated]
17:33:11: MST: br_id:000c.8582.3800 Prio:32773 Port_id:32770 Cost:0
17:33:12: MST[0] Tree timer expired (code 1)
17:33:12: MST[0]: Fa0/1 (hello=1 mport_count=0 tx_count=0
17:33:12: MST[0]: Fa0/24 (hello=1 mport_count=2 tx_count=0
17:33:12: MST[0] (re)starting transmit timer
17:33:13: MST[0] Tree timer expired (code 1)
17:33:13: MST[0]: Fa0/1 (hello=0 mport_count=0 tx_count=1
17:33:13: MST[0]: Fa0/24 (hello=0 mport_count=2 tx_count=1
17:33:13: MST[0] (re)starting transmit timer
so pls shed a light.
thanks
5 Replies 5
Mohamed Sobair
Level 7
Level 7
I am not expert in MST, the problem I missed MST show yesterday in Cisco tv due to some internet problem.
Anyways, From what I recognized, You missed to configure the Region.
In order for Bridges to have the same spanning-tree MST overview , they should be in the same region.
I would like also to have Francois's valuable comment on this, as he could give us excellent picture.
Mohamed
Mohamed,
thanks for ur reply. But it is not my story.
i had set the region name and revision number on all these 3 switches.
name=abc
revision=10
instant 3:vlan103, 104
instant 5:vlan105, 106
but anyway, thanks for ur comment.
Francois Tallet
Level 7
Level 7
Could you forward a "show span mst detail" for the relevant interfaces on the IOS boxes, and the equivalent on the catos box (probably some form of show spantree mst, can remember the exact command, but you must know;-)
I don't remember all the subtlety of the MST debug in the pre-standard release, but it seems indeed that the mrecords received on f0/1 are not displayed, while they are for f0/24.
Did you allow any vlan mapped to instance 3 and 5 on f0/1? We only create the MSTI information on this condition.
Francois
thanks, Francois
i had figured out the reason.
some trunking setting is inconsistent on my 4006 and 2950. after correct the setting, everything looks fine so far.
sh spanning-tree mst 3
###### MST03 vlans mapped: 103-104
Bridge address 000d.bd01.ac00 priority 32771 (32768 sysid 3)
Root address 0003.e316.e200 priority 24579 (24576 sysid 3)
port Fa0/1 cost 180000 rem hops 19
Interface Role Sts Cost Prio.Nbr Type
Fa0/1 Root FWD 180000 128.1 P2p
Fa0/24 Desg FWD 200000 128.24 P2p
j2950#sh spanning-tree mst 5
###### MST05 vlans mapped: 105-106
Bridge address 000d.bd01.ac00 priority 32773 (32768 sysid 5)
Root address 0003.e316.e200 priority 24581 (24576 sysid 5)
port Fa0/1 cost 200000 rem hops 19
Fa0/1 Root FWD 200000 128.1 P2p
Fa0/24 Altn BLK 200000 128.24 P2p
thanks again.
The vlans were not allowed or the port was not trunking, right?
F.
