MST
The_guroo_2
Level 2
Level 2
suppose we have 4 vlans 2,3,4,5 and they are in instance 10....if i want to make a perticular switch root for these vlans i will config them in mst instance 10 and then i can do root...for example
mst instance 10 vlan 2,3,4,5 root primary
i was looking at config and they have used prority 0 instaed of root primary what is the difference or is it a same thing???? what is the default prority and if we write 0 what happenes....thanks guys for looking
Giuseppe Larosa
Hello khan,
0 is the lowest possible priority value so the practical effect is the same.
the root primary is actually a macro that is executed once
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/spantree.html#wp1102122
Hope to help
Giuseppe
