multi area ospf on a single interface
mmercaldi
Community Member
I am in a situation where I need to to do multi area ospf on a single interface as it is now confirmed that the vpls isp will not pass vlan tags.  Juniper I see has this feature, https://www.juniper.net/documentation/en_US/junos/topics/topic-map/ospf-multiarea-adjacency.html
Is there a way on Cisco to do this either with broadcast, non broadcast or point-to-multipoint?
Will I be able to send ipv4 traffic over that and also will that work with ip base routers?
I think in OSPFv2 it looks something like this (excerpt from the document linked below):
interface Ethernet 0/0
Device (config-if)# ip address 10.0.12.1 255.255.255.0
Device (config-if)# ip ospf 1 area 0
Device (config-if)# ip ospf network point-to-point
Device (config-if)# ip ospf multi-area 2
Device (config-if)# ip ospf multi-area 2 cost 10
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_ospf/configuration/xe-16/iro-xe-16-book/iro-multi-area-adj-xe.html
