Multi-Point Interface VS Point-to-Point Interface
Iluvnetwork
Level 3
Level 3
1) Router1(f0/0) -- (f0/0)SW1(f0/1-23) -- 23PCS
2) Router1(s0/0) -- (s0/0)Router2(f0/0) -- (f0/0)SW1(f0/1-23) -- 23PCS
3) Router1(f0/0) -- (f0/0)Hub1(f0/1-15) -- 15PCS
I cannot classify whether the specific interface is point-to-point or point-to-multipoint.
First case:
Router1's f0/0 -> Point to Multipoint, SW1's f0/1-23 -> Point to Point
Second case:
Router1's s0/0 -> Point to Point, Router2's f0/0 -> Point to Multipoint, SW1's f0/1-23 -> Point to Point
Third case:
Router1's f0/0 -> Point to Multipoint, Hub's f0/1-15 -> No Idea, best guess is Point to Point
If I am wrong, please let me the correct answers. Plus, somehow I cannot just understand point-to-point/point to multipoint comparison pictures on google. If you know how to distinguish them, please share with me 🙂 I really want to know how to correctly classify whether the specific interface is multi-point or point-to-point.
Reza Sharifi
Point-to-point is usually referred to a directly connected link between 2 devices using a /30, /28. etc..
So, in you scenario, case 2, the connections between Router1(f0/0) -- Router2(f0/0)  is point-to-point.
Point-to-point could also be between 2 routers connection using a serial interfaces:                   Router1(s0/0) -- Router2(s0/0). You can't connect 2 devices together using serial on one site and Ethernet on the other side. The media type must be the same.
I meant Router(s0/0) --- (s0/0)Router2(f0/0)...
I editted the post. There should be no more confusion 🙂
