Multicast Data Drop on 3750X
James_S33
We are currently experiencing random multicast data dropouts on ports that are connected to a 3750X in VLAN ports.
A test PC was connected to a routed port and we do not have any dropouts of the multicast data.
We also took a 2960G and plugged it into VLAN ports on the 3750X.  Any test PC that is on the 2960G does not lose traffic.
The traffic only drops on PCs that are connected to a port on the 3750X that is in a VLAN.  The data drops are random and last approximatly 55-59 seconds
before we start receiving multicast traffic again.
I do not see any input/output errors on the interfaces
sh platform port-asic stat drop also show no drops
CPU runs at about 50% on the 3750X
Below is the configuration of the 3750X
Building configuration...
Current configuration : 8454
version 12.2
no service pad
service password-encryption
hostname XXXXX
boot-start-marker
boot-end-marker
enable password 1 XXXXXXX
no aaa new-model
clock timezone CST -6 0
clock summer-time CST recurring
switch 1 provision ws-3750x-12s
switch 2 provision ws-c3750x-48
system mtu routing 1500
ip routing
no ip domain-lookup
ip multicast-routing distributed
spanning-tree mode pvst
spanning-tree extended system-id
vlan internal allocation policy ascending
interface Loopback0
ip address 192.168.x.x 255.255.255.255
ip pim sparse-mode
ip igmp join-group 233.2.x.x
interface GigabitEthernet1/0/1
description Primary Route
no switchport
ip address 192.168.x.x 255.255.255.252
ip pim sparse-mode
ip ospf cost 2
interface GigabitEthernet1/0/2
description Secondary Route
no switchport
ip pim sparse-mode
ip ospf cost 100
interface GigabitEthernet1/0/3
description Test PC1
no switchport
ip address 192.168.x.x 255.255.255.128
ip pim sparse-mode
interface GigabitEthernet1/0/4
description Test PC2
no switchport
ip pim sparse-mode
interface GigabitEthernet 2/0/1
description Test PC3
switchport access vlan 3
interface GigabitEthernet 2/0/2
description Catalyst 2960G
interface GigabitEthernet 2/0/3
description Test PC4
switchport access vlan 4
interface GigabitEthernet 2/0/4
interface Vlan3
ip pim sparse-mode
interface Vlan4
ip pim sparse-mode
router ospf 10
redistribute connected subnets
network 192.168.0.0 0.0.255.255 area 0
ip http server
ip http secure-server
ip sla enable reaction-alerts
logging esm config
logging 192.168.x.x
line con 0
login local
speed 115200
line vty 0 4
login local
length 0
line vty 5 15
login local
ntp server 192.168.x.x
end
Reza Sharifi
Do you have the same issue if you are using different ports on the same 3750 or is it just one port that is causing problems?
We have tried multiple ports and still have the same problem.
Did you solve the problem?
We are currently experiencing multicast dropouts on 3750X in stack with 3750G (with multicast source). No dropouts between two 3750Gs in stack though. Mirroring a 3750G port with multicast trraffic to 3750X once again gives us no dropouts.
