Multicast Filtering Between VLANS
Kevin P Sheahan
Level 7
Level 7
I have the need to filter multicast between vlans as described below. PIM Sparse-Mode is being utilized for this multicast network and changing any Vlan to PIM Dense mode is not an option.
- Vlan 217 and Vlan 4 should not be communicating on mcast with any other vlan, including eachother (each vlan isolated).
-Vlan 64 and Vlan 80 are able to communicate witch each other on mcast but not with any other vlans (isolated vlan group).
-All other vlans can communicate mcast freely.
What I've created thus far is below. It does not appear to be the most elegant solution and would be difficult for the administrators to adjust as new requirements come along. Yes, I will be adding the appropriate link-local multicast addresses so as to not break routing and other dependent technologies. Any other solutions/ideas?
ip access-list ext ANY_CONN
permit ip any any
ip access-list ext MCAST_INTRA_217
permit ip 224.0.0.0 15.255.255.255 133.106.197.32 255.255.224.0
permit ip 133.106.197.32 255.255.224.0 224.0.0.0 15.255.255.255
ip access-list ext MCAST_ISOLATE
permit ip 224.0.0.0 15.255.255.255 any
permit ip any 224.0.0.0 15.255.255.255
ip access-list ext MCAST_INTRA_14
permit ip 224.0.0.0 15.255.255.255 10.23.0.0 255.255.0.0
permit ip 10.23.0.0 255.255.0.0 224.0.0.0 15.255.255.255
vlan access-map MCAST_ISOLATE_217 10
match ip address MCAST_INTRA_217
action forward
vlan access-map MCAST_ISOLATE_217 20
match ip address MCAST_ISOLATE
action drop
vlan access-map MCAST_ISOLATE_217 30
match ip address ANY_CONN
action forward
exit
vlan access-map MCAST_ISOLATE_14 10
match ip address MCAST_INTRA_14
action forward
vlan access-map MCAST_ISOLATE_14 20
action drop
vlan access-map MCAST_ISOLATE_14 30
action forward
exit
vlan filter MCAST_ISOLATE_217 vlan-list 217
vlan filter MCAST_ISOLATE_14 vlan-list 14
ip access-list ext MCAST_RESTRICT
permit ip 224.0.0.0 15.255.255.255 133.106.64.0 0.0.15.255
permit ip 133.106.64.0 0.0.15.255 224.0.0.0 15.255.255.255
permit ip 224.0.0.0 15.255.255.255 133.106.80.0 0.0.15.255
permit ip 133.106.64.0 0.0.80.255 224.0.0.0 15.255.255.255
vlan access-map MCAST_RESTRICT 10
match ip address MCAST_RESTRICT
action forward
vlan access-map MCAST_RESTRICT 20
action drop
vlan access-map MCAST_RESTRICT 30
action forward
vlan filter MCAST_RESTRICT vlan-list 64, 80
Thanks in advance.
Kind Regards,
Kevin
Kind Regards, Kevin Sheahan, CCIE # 41349
Kevin P Sheahan
Level 7
Level 7
My wildcard masks are jacked.. I did this in notepad so I didn't have the CLI to square me away when trying to enter the normal subnet mask.
Kind Regards,
Kevin
**Please remember to rate helpful posts as well as mark the question as 'answered' once your issue is resolved. This will help others to find your solution faster.
