Multicast, IGMP and 6509
ycae
We are facing a somewhat strange situation.
We have a server which is sending a multicast stream and which is connected to one of the ports of the 6509. on this 6509 we have also access switches connected. On all the switches we configured igmp snooping and on the 6509 we executed the command ip pim sparse-dense-mode.
Verifying the access switches, everything works as designed. The multicast flows only go to the ports which have requested to receive the flow.
However on the 6509 we are facing the situation that all the traffic coming from the multicast server is sent to all the ports. However this is something we do not like to have. So why is the 6509 sending the multicast stream to all the ports eventhough igmp snooping has been configured? Is there anything more we have to do on the 6509?
Thanks a lot for your support and if you need more information, just let me know.
Yves
Hello Yves,
I've given a look at bug toolkit for C6509 and 12.2(18)SXD6 and there are 31 bugs listed for IGMP. Some are related to IGMP snooping
I would suggest to try to upgrade to a newer IOS image and to try with it
what IOS image to choice depends on how is populated the chassis, if there are only standard linecards you could use 12.2(33)SXH5 if you have service-modules like FWSM or CSM or ACE you would need 12.2(33)SXI2 or later.
Hope to help
Giuseppe
6 Replies 6
Giuseppe Larosa
Hello Yves,
what is the multicast address used by the server?
with all ports you mean all the ports in the same vlan as the server or this happens on all vlans?
Hope to help
Giuseppe
An example multicast address that we use is 239.0.1.1
No only on the ports of the same vlan. But this shouldn't be the case. It should only send the multicast packets to the ports which required a grouping via a IGMP report.
Yves
Hello Yves,
I agree it should be able to optimize traffic on the vlan too
What IOS image is running on the C6509?
I ask this in order to search for possible bugs
what is the output of
sh ip igmp group Vlan vlan#
and
sh mac-address-table multicast igmp-snooping
Hope to help
Giuseppe
ycae
Hi Giuseppe,
we are running 12.2(18) SXD6.
Thanks for your help.
Yves
Hello Yves,
Hope to help
Giuseppe
Hi Giuseppe,
I only have line cards in that chasis so I will go with the 12.2(33)SXH5 version.
Where can I find the document with the list of the bugs?
Thanks a lot,
Yves
