Multicast Routing Pim-Sparse-Mode
ashleyreed4218
Hi All,
If I put ip pim-sparse-mode on an interface, and then issue a show ip mroute command and don't see the interface there, is that sufficient evidence to suggest that the interface isn't seeing the multicast?
Thank you in advance,
AR
John Blakley
You need to make sure that you enable multicast routing globally. You'd be able to put the command on the interface, but you should receive an error. If you put the command on the interface and do a "sho ip mroute", you won't see anything until you enable multicast routing with "ip multicast-routing" in global mode. After you do this, you should see the router listening for 224.0.1.40
(*, 224.0.1.40), 00:00:03/00:02:56, RP 0.0.0.0, flags: DCL
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    FastEthernet0/0, Forward/Sparse, 00:00:03/00:02:56
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
HTH,
John
Thank You John,
I tried to go into global:
ROUTER1(config)#ip pim sparse ?
It wont let me issue the pim sparse-mode command? Am I doing something wrong?
The "ip pim sparse" command goes under the interface that you want to enable pim on. You'd enable "ip multicast-routing" at the global level:
R2(config)#ip multicast-routing
R2(config)#int fa0/0
R2(config-if)#ip pim sparse
R2(config-if)#ip pim sparse-
R2(config-if)#do sh ip m
*Mar  1 01:00:08.483: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 192.168.12.2 on interface FastEthernet0/0r
R2(config-if)#do sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.0.1.40), 00:00:03/00:02:58, RP 0.0.0.0, flags: DCL
    FastEthernet0/0, Forward/Sparse, 00:00:03/00:02:58
R2(config-if)#
HTH,
John
As John suggested - Multicast routing should be enabled in global config and then PIM on per interface basis.
Once configured number of interfaces can also be checked configured for PIM with command-
sh ip pim interface
Ajay
