Multicast traffic issue with 3750x stack
Does 'no ip cef optimize neighbor resolution' create any issues for multicast traffic? I have implemented this command on 3750x switch stack to avoid a bug issue running on 15.0-2.SE2.
I'm broadcasting some multicast traffic from our data center to a destination which is having above 3750x as a core. Non of the users behind this 3750x cannot receive any multicast traffic. It worked prior to upgrade the switch to 15.0 code.
Thanks in advance.
Jon Marshall
Did multicast work after you upgraded but before you added that command ?
Or did you not try that.
What do the basics show ie "sh ip mroute" on the switch and can you see the stream being received by the switch etc.
Jon
