Multicasting problems on 3745 with switch card
fsux
When we configure multicasting on our 3745 router with a switch card (NMD-36-ESW) it will not pass the data to other networks. There are multiple vlans set up on the switch card, with corresponding vlan interfaces. We have a Windows server running Windows Media server on one VLAN as our multicast source. We have hosts off of other vlans as clients using Windows Media Player. This is a very simple design. We enabled ip multicast routing, enabled ip pim
sparse-dense-mode on the corresponding vlan interfaces, and are unable to get the clients to receive the multicast data. When we moved this network setup to use a single 3620 and a 3550 (layer 2 only), it works. We also tried it using the 3550 exclusively, with ip routing
enabled, and it worked. We are led to believe that the issue is with the 3745 router and switch card. Anyone have any suggestions???
Harold Ritter
Level 12
Level 12
Do you only have one switching module installed in the 3745? If not, you might need to enable stacking between the switching modules.
Please refer to the following URL, for more information on intra-chassis stacking:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00800b5d67.html#wp1485397
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
We only have one card in the router, but I did look into the documentation just in case there was other information. To this point we still don't know what the issue is.
