Multilayer switch
arifnurfajar24
Community Member
Hi, I have Multilayer switch connected to two router. I already configure the IP address in router and VPCS. But when I'm tried to route the network, the routing doesn't work and when I check the routing table using command "show ip route" the routing isn't appear. I already try with static, rip, and ospf and still doesn't work.
Each interface already configure with "no switchport" to make the interface capable to route. Did I miss something? Please help me. Here the table routing and topology I used. thank you
Device
Interface
IP Address
R1g0/0192.168.100.2/24
R2g0/0192.168.200.2/24
ESW1f1/0192.168.100.1/24
 f1/1192.168.200.1/24
 f1/2192.168.3.1/24
VPCSe0192.168.3.2/24
Mark Malone
Have you got ip routing turned on
http://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/41860-howto-L3-intervlanrouting.html
