multilayerswich and not pinging other device
as12john_A
 I would like to send my x.pkt for you, to help me for reviewing. However, I am a beginner and don't know how to send the file for you HERE.
7 Replies 7
Julio E. Moisa
Is possible to copy and share the configuration? also have you enabled the command: ip routing, on the Layer 3 switches?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
thanks. Yes I have already enabled it.
An example of config could be (using SVI)
SWITCH 1
ip routing
vlan 10
interface vlan 10
no shutdown
ip address 172.16.10.1 255.255.255.0
interface g1/24
description >>>PORTS-BETWEEN-SWITCHES<<<
switchport
switchport mode trunk
no shutdown
SWITCH 2
ip routing
vlan 10
interface vlan 10
no shutdown
ip address 172.16.10.2 255.255.255.0
interface g1/24
switchport
no shutdown
Now if you are doing a point to point with layer 3 ports, example:
Remove the vlan and then
interface g1/24
no switchport
no shutdown
Hope it is useful
Thanks.
use:
https://wetransfer.com/
to send the file. You can send it to:
pauwen@hotmail.com
you cannot upload .pkt files directly, you have to use an external file sharing program such as Google Drive, and place the download link into your post...
Fotiosmark
sent fotiosmark@gmail.com
describe ur issue and don't forget to rate as helpful
