multilinking e1 lines and runing eigrp
carl_townshend
Hi all
If I have 2 e1 lines and want to run eigrp on them, would I create a loopback on the router, then give the physical interaces ipunnumbered loopback 0, then multilink them, would eigrp see them as 1 link on the other side ?
Giuseppe Larosa
Hello Carl,
almost correct but if you create a PPP multilink all L3 configuration goes under interface multilink:
int ser0/0
no ip addr
enc ppp
ppp multilink 1
int ser0/1
no ip addr
enc ppp
ppp multilink 1
int multilink 1
enc ppp
ppp multilink 1
ip address unnumbered loop0 | ip address x.x.x.1 255.255.255.252
personally I would give an ip address to the multilink on both sides using an ip subnet /30.
to be able to build EIGP adjacency when using ip unnumbered loop0 some more tuning may be needed
Hope to help
Giuseppe
hi
can you tell me why the command ppp multilink 1 is in the multilink interface?
also why would it need tuning? do you mean putting a bandwidth statement on the loopback interface?
Hello Carl,
the correct part of my post is that you need to use the multilink interface and you cannot bundle and at the same time assign an ip address (directly or via ip unnumbered ) to member links
about tuning, my concerns are about the capability to build the EIGRP adjacency if the loopback ip addresses are not in the same subnet (if you use /32).
For this reason I recommend to give an ip address to the multilink that is a setup I've already used successfully
for PPP multilink see
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_media-ind_multi_ppp_ps6922_TSD_Products_Configuration_Guide_Chapter.html#wp1022210
the key commands are
ppp multilink
and
ppp multilink group group-number
in this my example on the fly is wrong
Sorry for this
Hope to help
Giuseppe
