Multiple Layer 3 switch routing
L4d1k
Community Member
I am trying to utilize our Layer 3 switches for VLAN routing.
Can I get some assistance with this configuration:
VLAN 1 Default (transport)
192.168.2.0/22
VLAN 10 VoIP
192.168.2.0/24
VLAN 20 Staff
192.168.3.0/22
VLAN 30 Guest
192.168.4.0/22
Local DHCP (not Meraki)
192.168.2.30
Local DNS
192.168.2.30
Firewall MX250
MS350 L3 switches 5x
MS220 L2 Switches 5x
Not sure in which order or if I am missing anything but it looks like it takes 3 different places to set it up:
1. under switches/ configure/ DHCP & routing
Interfaces
2. under switches/ configure/ DHCP & routing
Static routes
3. Security & SD-Wan/ configure/ Addressing & VLANs
Static Routes
Thank you!
5 Replies 5
You are right.
1: All your VLANs that you want to route internally.
2: typically a default route is fine here.
3: Routes to all VLANs that you configured in Step 1. But also all VLANs that you need to segment for security. For example your DMZs. Depending on the environment, I have all my VLANs here and not on the L3-switch.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Philip D'Ath
Meraki Community All-Star
Yes that is the document I was using.
I just wish there was one with more details and included more pictures or videos with the Meraki interface and what was configured.
Ideally with multiple L3 switches and multiple VLANs
CMR
You need non overlapping subnets:
192.168.2.0/22 - this includes IP addresses 192.168.0.1 to 192.168.3.254
VLAN 10 VoIP
192.168.2.0/24 - overlaps with the above /22
VLAN 20 Staff
192.168.3.0/22 - this is the same as the first subnet
VLAN 30 Guest
192.168.4.0/22 - this is also the same.
You need unique subnets.
If my answer solves your problem please click Accept as Solution so others can benefit from it.
L4d1k
Community Member
Yes, the subnets are unique.
I didn't put the subnets in use I only used it as an example and didn't do the right subnet mask.
For test purposes/24 on all subnets should be ok.
