Multiple MAC on the same interface (802.1x)
Hevin27
Level 2
Level 2
Hi Guys,
Recently ran into a problem. I enabled a simple 802.1x authentication on the switch and recently noticed that some ports had a large number of MAC addresses, when in fact only one PC was connected to that interface. Do you have any suggestions? The show mac address below shows only a subset of the macs under this interface, and each MAC has an authenticated session.
The following logs also appear:  %DOT1X-5-FAIL: Switch 1 R0/0: sessmgrd: Authentication failed for client
interface GigabitEthernet2/0/22
switchport access vlan 8
switchport mode access
switchport voice vlan 80
device-tracking attach-policy Tracking_Policy
authentication host-mode multi-auth
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
mab
dot1x pae authenticator
dot1x timeout server-timeout 5
dot1x timeout tx-period 3
dot1x timeout supp-timeout 3
dot1x max-req 3
dot1x max-reauth-req 3
spanning-tree portfast
spanning-tree bpduguard enable
B4-5F2-C9300Lx5_8.86#sh mac address | in 2/0/22
8 8469.939c.88bf STATIC Gi2/0/22
990 0000.0000.010a STATIC Gi2/0/22
990 0000.0000.011a STATIC Gi2/0/22
990 0000.0000.012d STATIC Gi2/0/22
990 0000.0000.014c STATIC Gi2/0/22
990 0000.0000.015e STATIC Gi2/0/22
990 0000.0000.016f STATIC Gi2/0/22
990 0000.0000.017f STATIC Gi2/0/22
990 0000.0000.018a STATIC Gi2/0/22
990 0000.0000.019e STATIC Gi2/0/22
990 0000.0000.01b8 STATIC Gi2/0/22
990 0000.0000.01c8 STATIC Gi2/0/22
990 0000.0000.01e1 STATIC Gi2/0/22
990 0000.0000.01e4 STATIC Gi2/0/22
990 0000.0000.01f2 STATIC Gi2/0/22
990 0000.0000.0214 STATIC Gi2/0/22
990 0000.0000.0275 STATIC Gi2/0/22
990 0000.0000.02ac STATIC Gi2/0/22
990 0000.0000.02d5 STATIC Gi2/0/22
990 0000.0000.02e4 STATIC Gi2/0/22
990 0000.0000.031f STATIC Gi2/0/22
990 0000.0000.0333 STATIC Gi2/0/22
990 0000.0000.033f STATIC Gi2/0/22
990 0000.0000.0341 STATIC Gi2/0/22
990 0000.0000.0350 STATIC Gi2/0/22
990 0000.0000.040f STATIC Gi2/0/22
990 0000.0000.0436 STATIC Gi2/0/22
990 0000.0000.04b8 STATIC Gi2/0/22
990 0000.0000.04c9 STATIC Gi2/0/22
990 0000.0000.052a STATIC Gi2/0/22
990 0000.0000.052c STATIC Gi2/0/22
990 0000.0000.052d STATIC Gi2/0/22
990 0000.0000.054b STATIC Gi2/0/22
990 0000.0000.0573 STATIC Gi2/0/22
990 0000.0000.0592 STATIC Gi2/0/22
990 0000.0000.05bd STATIC Gi2/0/22
990 0000.0000.0739 STATIC Gi2/0/22
990 0000.0000.0797 STATIC Gi2/0/22
990 0000.0000.07c1 STATIC Gi2/0/22
990 0000.0000.07d7 STATIC Gi2/0/22
990 0000.0000.0828 STATIC Gi2/0/22
990 0000.0000.096c STATIC Gi2/0/22
990 0000.0000.097d STATIC Gi2/0/22
990 0000.0000.0a36 STATIC Gi2/0/22
990 0000.0000.0b34 STATIC Gi2/0/22
990 0000.0000.0b5d STATIC Gi2/0/22
990 0000.0000.0bfe STATIC Gi2/0/22
990 0000.0000.0d3d STATIC Gi2/0/22
990 0000.0000.154d STATIC Gi2/0/22
990 0000.0000.1585 STATIC Gi2/0/22
990 0000.0000.1847 STATIC Gi2/0/22
990 0000.0000.195a STATIC Gi2/0/22
990 0000.0000.1996 STATIC Gi2/0/22
990 0000.0000.1ac6 STATIC Gi2/0/22
990 0000.0000.1c2d STATIC Gi2/0/22
990 0000.0000.1cd1 STATIC Gi2/0/22
990 0000.0000.1d8a STATIC Gi2/0/22
990 0000.0000.1e81 STATIC Gi2/0/22
990 0000.0000.1ec2 STATIC Gi2/0/22
990 0000.0000.2081 STATIC Gi2/0/22
990 0000.0000.215c STATIC Gi2/0/22
990 0000.0000.21b1 STATIC Gi2/0/22
990 0000.0000.23ba STATIC Gi2/0/22
990 0000.0000.2601 STATIC Gi2/0/22
990 0000.0000.2799 STATIC Gi2/0/22
990 0000.0000.29af STATIC Gi2/0/22
990 0000.0000.2b2e STATIC Gi2/0/22
990 0000.0000.2b40 STATIC Gi2/0/22
990 0000.0000.2d91 STATIC Gi2/0/22
990 0000.0000.2dae STATIC Gi2/0/22
990 0000.0000.2dd2 STATIC Gi2/0/22
990 0000.0000.2f56 STATIC Gi2/0/22
990 0000.0000.31e7 STATIC Gi2/0/22
990 0000.0000.328b STATIC Gi2/0/22
990 0000.0000.39c4 STATIC Gi2/0/22
990 0000.0000.3b01 STATIC Gi2/0/22
990 0000.0000.3b04 STATIC Gi2/0/22
990 0000.0000.3f5e STATIC Gi2/0/22
990 0000.0000.40d3 STATIC Gi2/0/22
990 0000.0000.446a STATIC Gi2/0/22
990 0000.0000.4572 STATIC Gi2/0/22
990 0000.0000.4da5 STATIC Gi2/0/22
990 0000.0000.4e7c STATIC Gi2/0/22
990 0000.0000.54ba STATIC Gi2/0/22
990 0000.0000.551e STATIC Gi2/0/22
990 0000.0000.56e4 STATIC Gi2/0/22
990 0000.0000.57ec STATIC Gi2/0/22
10 Replies 10
Mark Elsen
 - Strange address , look at https://mac-address.alldatafeeds.com/mac-address-lookup/jRGqWdE956 , right column , seems to be related to some kind virtual service , offering load balancing or connectivity (e.g.) ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
On the other port, it has these MACs, I don't know what happened. When I shutdown and no shutdown the interface, the addresses disappear and reappear after a while.
990 18f7.6496.4d97 STATIC Gi2/0/46
990 1a35.9fb5.63e2 STATIC Gi2/0/46
990 1cef.3e0f.ebc2 STATIC Gi2/0/46
990 1e12.efc1.6e52 STATIC Gi2/0/46
990 1e6d.fb7d.123e STATIC Gi2/0/46
990 1ef9.6552.0719 STATIC Gi2/0/46
990 202f.6363.6d5f STATIC Gi2/0/46
990 20ff.e325.bfe8 STATIC Gi2/0/46
990 220e.d02c.c2c7 STATIC Gi2/0/46
990 223e.4568.bff4 STATIC Gi2/0/46
990 2278.2638.4740 STATIC Gi2/0/46
990 22a1.829a.aba7 STATIC Gi2/0/46
990 22a7.a56b.d99d STATIC Gi2/0/46
990 260c.3800.0088 STATIC Gi2/0/46
990 2867.e888.7430 STATIC Gi2/0/46
990 2879.6828.269c STATIC Gi2/0/46
990 2aae.d25c.9ea0 STATIC Gi2/0/46
990 2c74.c016.8dcd STATIC Gi2/0/46
990 2cd9.5270.9eaf STATIC Gi2/0/46
990 2cf7.d4c6.31a2 STATIC Gi2/0/46
990 2e1e.ecfe.0e1c STATIC Gi2/0/46
990 2e46.5e59.0d7c STATIC Gi2/0/46
990 3053.7856.f985 STATIC Gi2/0/46
990 3057.4e47.3662 STATIC Gi2/0/46
990 3082.0739.a103 STATIC Gi2/0/46
990 322d.617a.7363 STATIC Gi2/0/46
990 326a.9196.f118 STATIC Gi2/0/46
990 3280.f5f6.f807 STATIC Gi2/0/46
990 32bb.d1e9.cf66 STATIC Gi2/0/46
990 344f.0db1.21b3 STATIC Gi2/0/46
990 34a3.3fee.181d STATIC Gi2/0/46
990 34a9.1a33.ca7e STATIC Gi2/0/46
990 34e9.a08c.dadc STATIC Gi2/0/46
990 3671.3a56.9cec STATIC Gi2/0/46
990 36d2.8f59.f80f STATIC Gi2/0/46
990 3a33.373a.3234 STATIC Gi2/0/46
990 3c00.0000.3b00 STATIC Gi2/0/46
990 3c3f.786d.6c20 STATIC Gi2/0/46
990 3e00.3200.3000 STATIC Gi2/0/46
990 3eb2.8e33.784b STATIC Gi2/0/46
990 3ec8.97c6.fb76 STATIC Gi2/0/46
990 4009.09a5.ed55 STATIC Gi2/0/46
990 4030.b1d6.2e0c STATIC Gi2/0/46
990 409e.c40f.17c5 STATIC Gi2/0/46
990 40f3.32ce.9934 STATIC Gi2/0/46
    - Make sure  that you don't have a loop and or that spanning tree is properly setup for vlan 990 ,
 M.
authentication host-mode multi-auth <<-
if the first host is auth and success then all other host can auth and authz
but for mac address check if PC run any VM
https://community.cisco.com/t5/switching/multiple-mac-addresses-found-in-one-interface/td-p/2289317/page/2
the Cisco TAC recommend use DHCP snooping & DAI
so either this PC have VM or there is virus in PC
please check my other comment
 Seems you have a switch connected to this port or a server running multples virtual machines.
Hi Flavio,
No, I've checked the connections and there is only one PC connected to this port.
Weird. One PC with so  many Mac address
Don't know what happened, there are more than 10,000 clients in the intranet, and only a few PCs have this problem
