Multiple SSID Vlans tagged - not getting DHCP over Cisco trunk port
Shawn Kingston
Hardware and network setup as follows:
Meraki AP connected to Cisco 2960
>Cisco 2960 connected to Cisco 4500 stack.
>Cisco 4500 stack splits traffic, (Comcast Internet) / AT&T MPLS connection to our main site (Cisco 9300 stack)
>Cisco 9300 Stack to DHCP server and Fortigate FW.
Multiple SSID's setup on the AP with different VLAN tagging, 22,25,60,130
Cisco 2960 switchport config:
interface GigabitEthernet1/0/18
description AP Test
switchport trunk allowed vlan 1,22,25,60,130
switchport mode trunk
end
None of those vVans are on the DHCP server, they are being given by the Fortigate FW at the main site.
1. How can I get the trunk port to pass the different VLAN traffic? Currently it pulls a DHCP address for the AP from the native vlan 1.
2. How can I point the switch to look for the DHCP scope being given from the fortigate on the other side?
FWIW, If I plug the AP into the 9300 on the main site (trunk port), I am able to pull correct IP addresses from correct scopes with vlan tagging on the SSID's. Just not able to do it over the MPLS connection? The VLANs are in the switch, only native vlan 1 has an ip address assigned.
Thank you in advance!!
0 Replies 0
