Multiple WS-2960CX-8PC-L won't allow use of both fiber ports.
treimers1
Hi everyone -
I have a bit of a strange problem.
I have THREE of the WS-C2960CX-8PC-L switches
that will not allow me to use both of the SFP ports.
Links to "yes this should work" from the Datasheets are below.
Troubleshooting thus far:
- This is true when connecting ANY fiber optical device using ANY fiber transceiver (Cisco, CXTec, etc) to either of those ports. You can use ONE fiber port -- and both copper ports.
You cannot use all FOUR (2 fiber, 2 copper) uplinks at the same time.
I've moved the SFPs/fiber patches to two OTHER Cisco switches and had links come up - the SFPs and fiber patches are just fine, no bad hardware.
But as soon as I try to connect the second SFP (either one) of the fiber ports to an SFP, and bring up _anything_ on the other end, the link _will not_ come up.
The SFP does show up in 'show inv' == but no link will happen.
2960-CX
(LAN Base)
8
Non PoE
8 x 1G
2 x 1 G SFP
2 x 1 G Cu
WS-C2960CX-8TC-L
PoE+
(124W)
8 x 1G
2 x 1 G SFP
2 x 1 G Cu
WS-C2960CX-8PC-L
This from the 3560 portion
 Can you use both the 2 x 10G SFP+ uplinks along with 2 x Multigigabit ports on WS-C3560CX-8XPD-S at the same time?
A.     Yes, all 4 ports can be used at the same time and are line rate.
Table 4.       Cisco Catalyst 2960-X Compact Switch Models and Default Software
Model
Ethernet Ports
PoE
Output Ports
Available
PoE Power
Uplinks
Default Software
2960CX-8TC-L
8 x 10/100/1000 Gigabit Ethernet
N/A
2 x 1G copper plus
2 x 1G SFP
LAN Base
2960CX-8PC-L
8 PoE+
124W
2 x 1G copper plus
2 x 1G SFP
LAN Base
Note:    All four uplink ports (two copper and two fiber) can be used simultaneously and also as downlinks.
treimers1
A further quick comment ---
I have, of course, swapped SFPs/fiber patches around
on various ports -- this is happening on at least three different 2960CX switches, so I don't think it's failed SFP slots, nor is it failed SFPs/bad patches, etc.
If it were a problem with shared ports, I'd expect not to be able to share the copper uplink/downlink ports either - ie, I'd be able to get ONE copper link and ONE fiber link up.
As it is, I can get both copper uplinks and one fiber port working -- not all four.
For those who will want to know the firmware involved:
c2960cx-universalk9-mz.152-4.E2.bin
Both SFPs do show up - no slot failures
sh inventory
NAME: "1", DESCR: "WS-C2960CX-8TC-L"
PID: WS-C2960CX-8TC-L , VID: V03 , SN: FOC2030Z67Q
NAME: "GigabitEthernet0/11", DESCR: "1000BaseLX SFP"
PID: GLC-LH-SMD , VID: V01 , SN: AXCLHSMD004949
NAME: "GigabitEthernet0/12", DESCR: "1000BaseLX SFP"
PID: GLC-LH-SMD , VID: V01 , SN: GTYW2777
One of the other affected switches is running:
c2960cx-universalk9-mz.152-3.E2.bin
So not even the same versions of software --
Thanks for any advice... Tim
Punt to top of the list for some to see this...
Has anyone got any ideas?
Thanks Tim
