My DHCP is not working
Jaydn Teoh
Hey guys, i have a router connected to a switch. The switch configures as a server, with 4 client switches. all 4 client switches have 4 PCs. There are 4 vlans configured, but i did dhcp configuration and it seems that it is failing to connect.
M02@rt37
@Jaydn Teoh,
ok, first on your Murdoc ROuter this is Gi0/0 to connect to HeadSwitch, not Gig0/1
Then add the command on your murdock Router -- MurdochD(config)#service dhcp
Also the config of access port on your switches is not good. For example here:
Put this config:
It's should be good:
Best regards
14 Replies 14
 If this is a PacketTracer project,  would be easier if you attach it here. You just need to zip the file first.
Here's my pkt file
M02@rt37
Hello @Jaydn Teoh,
Have you got a network topology to show us?
@Flavio Miranda, talk about paket tracer too. It should be easier for us to help you.
Thanks.
Best regards
Jaydn Teoh
Here's my topology. Thankyou for responding.
Hi @Jaydn Teoh
  Did you got this to work?
 I have found some problems on the file you attached and it would not be possible it to work. Just check on you if you fixed or maybe I got the wrong file.
 For example, you configured the interface Gi0/0 but you connected the switch into interface Gi0/1. But, I see other issues also.
Hi, I did get this to work. I have found that there are a few problems with the vlans. I did the right configurations for the vlan and changed the interface to g0/0. after that everything worked fine.
Great!
Wizard4777
use ip helper command to distribute ip addresses via dhcp
Hello @Wizard4777,
no need of ip helper address in this case. Sw L2 do the job with the broadcast due to DHCP meassages.
You need ip help address or relay dhcp if this broadcast messages have to pass throught Router ; because Router drop broadcast. Then with this command on a routeur, your broadcast is "convert" to unicast packet.
Best regards
Jaydn Teoh
I did #sh ip dhcp pool command on my switch and it shows that nothing is connected. Means that my switch is not connected to the router?
M02@rt37
@Jaydn Teoh,
Put this config:
Best regards
hey thank for replying, do you mean i should connect fast ethernet to gigabit?
@Jaydn Teoh,
Look Giga interfaces on your Murdoc Router. Giga0/1 is the bad one, you need to connect the giga0/0 to the HeadSwitch.
Best regards
Jaydn Teoh
Thank you. I actually done fast Ethernet to giga0/0. everything works fine now. thank you so much.
