04-28-2015 06:18 AM - edited 03-07-2019 11:46 PM
Hello ,
I am facing an issue with Nexus 2K airflow. It is sending hot air in the cold isle. I think there are two different models for airflow. Is there something that can be done to fix this issue? This is happening on N2K-C2232TM-E-10GE .
04-28-2015 06:29 AM
Yes your correct there are different airflow's available , unfortunately no fix but to change them this is hardware issue
04-28-2015 06:41 AM
I just checked the specs. i received that "B" fan and PS. Though I did not specify that I wanted reverse so I am wondering what is the standard?
N2200-PAC-400W-B
N2K-C2232-FAN-B
N2232TP-E-BA-BUN Reversed airflow/AC pack
04-28-2015 06:56 AM
thats the info below , same thing happened our DC , our vendor supplied us the wrong airflow fans had to be binned and re-ordered
• N22xx-FA-BUN is the default option for standard airflow with an AC power supply (Cisco Nexus 2200 chassis, one fan with standard airflow (front to back, aligned with port-side exhaust), and two AC power supplies)
• N22xx-BA-BUN is the reversed-airflow option with an AC power supply (Cisco Nexus 2200 chassis, one fan with reversed airflow (back to front, aligned with port-side intake), and two AC power supplies)
• N22xx-FD-BUN is the standard-airflow option with a DC power supply (Cisco Nexus 2200 chassis, one fan with standard airflow (front to back, aligned with port-side exhaust), and two DC power supplies)
