N2K forwarding rate
yamenginena
Dear all
I would like to ask if FEX N2K module are working with
- non blocking mode or what called wire speed or not
- local switching within module ports
Reza Sharifi
The FEXs do not do local switching.  If you need to go from port 1 to port 2, the packet goes up to the parent switch and gets switched there from port 1 to port 2.
http://packetlife.net/blog/2012/may/7/some-cisco-nexus-design-considerations/
Reza Sharifi
