N5K : a way to log CLI commands issued by users ?
guillerm
N5K NX-OS 7.0.5
Is there a way to log (via Syslog, or in the internal buffer) all the CLI commands issued by the users (as well as the user name and its IP address) as some networks equipments do ?
thanks
Reza Sharifi
If you add command:
"terminal log-all" it will log all commands including the show commands.
Reza Sharifi
If you add command:
well, I coded terminal log-all via conf t;
and tried to issue some show commands ; none has been logged when I use "show log last 40" to view the internal log file ...
any idea ?
thanks
well, it works !
the command to list this log is : show accounting log all
thanks a lot
