NAS not able to add Cisco WS-C6506
Sarasaqlain
Can any one help me providing a better solution for the folling problem.
When adding the device either with Wizard or Device Driver "Cisco switches, Catalyst Series, hybrid text mode, Catalyst OS" it looks like NAS is able to connect the device and then logs into the switch. For some reason it seems to retry logging. Can you help with this?
Here's the log entries involved.
Login / Authentication - Last successful password:
(Device-specific password)
Connect - Attempting connection via telnet to 192.x.x.x (port 23)
Send: ^U
Expect: [-re assword:|nter PASSCODE:, sername:, (enable), >,
-re $undeterministic_prompt]
Receive:
Cisco Systems Console
Enter password:
Send: {SECURE STRING}
Expect: [(enable), -re assword:|nter PASSCODE:, -re
tokencode:|ext PASSCODE:, >, new tokencode:, Enter a new PIN,
Authentication failed, -re $undeterministic_prompt]
Receive: CORESW03
Error: Timeout after waiting 10 seconds
Error:
Thanks in Advance!!!
Sara
didyap
Level 6
Level 6
