Nat based on destination
srikanth ath
Level 4
Level 4
Im missing something in below config.. can you please help me out.
          10.10.10.4/30                      10.10.10.0/30
R3--------------------------------R1--------------------- ------------R2
                                   Lo1: 172.16.15.0/24
The above is my network setup.. I have two interface on R1 connected to R2 and R3, these two are enabled with nat outside and loopback interface is with nat inside.
so here i want to nat based on the destination
if Lo1 tries to reach 10.10.10.4/30 should go via int fa 0/1 connected to R3.
Lo1 tries to reach 10.10.10.0/30 should go via int fa 0/0 connected to R2.
Route-map will do but how should i give the nat statement.... below is my config. pls help me.
interface Loopback0
ip address 172.16.15.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.10.5 255.255.255.252
ip nat outside
duplex auto
speed auto
ip classless
no ip http server
no ip http secure-server
ip nat inside source route-map nat-route interface FastEthernet0/1 overload-------------------Here iam getting confused....
access-list 100 permit ip 172.16.15.0 0.0.0.255 10.10.10.0 0.0.0.3 log
access-list 101 permit ip 172.16.15.0 0.0.0.255 10.10.10.4 0.0.0.3 log
route-map nat-route permit 1
match ip address 100
set interface FastEthernet0/0
route-map nat-route permit 2
match ip address 101
set interface FastEthernet0/1
Srikanth
srikanth ath
Level 4
Level 4
.....could
SOmeone help me on this?
Yes, i could change the config. and it worked for me.
Felt like, It might be usefull for someone. so below is the changes i made.
Earlier i assumed only one route-map can be  added for Nat.
so here i have done with using PBR in  NAT. which worked.
ip nat inside source route-map nat-route interface FastEthernet0/0 overload
ip nat inside source route-map nat-route-2 interface FastEthernet0/1 overload
route-map nat-route-2 permit 1
