nat between two private networks
wpansophon
hello
i cant ping between 2 private networks like PC0 to PC4 .
may be its the dynamic NAT on both router R_L,R_R that cause the problem.
is there any way to solve it without setting static nat?
THANK YOU
Julio E. Moisa
I have enabled a debup ip NAT on the router R_L, I am able to see the translation but no receiving an answer. Im seeing the computers are in different networks, Is NAT just for testing?
Please let me check the configurations.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
yes,its for testing.
thank you for your help
Ok please let verify the config, and let me share my findings.
