NAT capable device with high throughput
Jeroen Huysmans
I'll have to replace an old WS-C3550-24. Reasons for this: EOL/EOS & we'll need a NAT capable device...
As I understood, the only L3 catalyst that is able to perform NAT is a 6500? Is that correct?
If the above is correct, it seems I can only replace the setup by using a router/ASA with a L2 switch.
A router with high throughput (+/- 300Mbps) is hard to find, especially as NAT will require CPU resources...
So, my best (affordable price) solution is getting an ASA5520 (450Mbps FW throughput) and a L2 switch?
regards,
Jeroen
Latchum Naidu
Hi Jeroen,
Yes, NAT feature available in L3 catalyst switches that are 6500 series.
Your option is getting an ASA5520 is a good idea, you can do multiple vpn and you can use ultimate NAT & PAT features like port forward like that.
And if you go with version 8.0 and later supports the Enhanced Interior Gateway Routing Protocol also.
Please rate all the helpfull posts.
Naidu.
