NAT issues
tonymctony
Community Member
Greetings,
I have the following issue:
I've got a 2821 router configured for NAT. It's supposed to grant access to a webserver on the local network at address 192.168.1.46, port 8080 from the outside network. The network address translation is working, I can see it with this command:
master#sh ip nat statistics
Total active translations: 4 (0 static, 4 dynamic; 4 extended)
Peak translations: 8, occurred 00:19:28 ago
Outside interfaces:
GigabitEthernet0/1
Inside interfaces:
GigabitEthernet0/0
Hits: 54 Misses: 0
CEF Translated packets: 54, CEF Punted packets: 0
Expired translations: 15
Dynamic mappings:
-- Inside Source
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
However, the web server is still unreachable - no traffic is coming from it when I try to access it from the outside. Please help troubleshoot this, I am at a loss here.
Here is my router's config:
master#sh running-config
Building configuration...
version 15.1
service config
service password-encryption
hostname master
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.151-4.M10.bin
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
archive
log config
hidekeys
redundancy
interface GigabitEthernet0/0
description LAN
ip address 192.168.1.3 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description WAN
ip address <Public IP address given by ISP> 255.255.255.0
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static tcp 192.168.1.46 8080 interface GigabitEthernet0/1 8080
ip nat inside source list 100 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 <ISP's gateway>
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
control-plane
mgcp profile default
Is the Web server reachable (pingable) from outside and does it resolve to 192.168.2.46 correctly? What is the output of "sh ip nat translation"?
7 Replies 7
Reza Sharifi
Can you test using the actual IP address of the service provider?
ip nat inside source static tcp 192.168.1.46 8080 <ip address of the provider> 8080 extendable
Thank you for the suggestion,  but no change.
Here's what I've done: I've removed the previous line like this:
no ip nat inside source static tcp 192.168.1.46 8080 GigabitEthernet0/1 8080
and added yours:
I cannot ping it from outside, as I have said before: the connection is not established.
However, I see that NAT is working:
master#sh ip nat translations
Pro Inside global         Inside local          Outside local         Outside global
tcp <gateway public IP>:8080   192.168.1.46:8080     <gateway public IP>:50456  <gateway public IP>:50456
tcp <gateway public IP>:8080   192.168.1.46:8080     ---                   ---
your NAT looks OK.
Are you sure your web server is really working on port 8080?
BR,
Milan
Absolutely:
master#telnet 192.168.1.46 8080
Trying 192.168.1.46, 8080 ... Open
GET /index.html
<?xml version="1.0" encoding="ISO-8859-1"?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"                 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">        <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"><head><title>Apache Tomcat</title></head><body>                                                              <h1>It works !</h1><p>If you're seeing this page via a web browser, it means you've setup Tomcat successfully. Congratulations!</p>
The solution was trivial, as most of them are - the local web server did not have a proper default gateway set. Changing that to the router that I am configuring fixed the issue. Thank you everyone, you've led me to the right solution.
