NAT problem?
yskent0423
Community Member
My server can send to router 1, router 2 and multilayer switch, the router 2 and multilayer sw can't send to server. The server and router 1 also can't send to pc, same situation pc can't send to server but can send to router 1.
Router 1 configuration
hostname R1
enable secret 5 $1$mERr$NL29xH54hwvZoGzIJj1v40
ip dhcp pool DNSServer
network 192.168.15.0 255.255.255.0
default-router 192.168.15.1
dns-server 100.10.0.1
no ip cef
no ipv6 cef
spanning-tree mode pvst
spanning-tree vlan 5,10,15,20,30,40,50,88,90,99 priority 4096
interface FastEthernet0/0
ip address 192.168.15.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/3/0
ip address 192.168.90.1 255.255.255.0
ip nat outside
clock rate 128000
interface Serial0/3/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router rip
network 192.168.90.0
ip nat inside source static 192.168.15.1 192.168.90.1
ip default-gateway 192.168.99.1
ip classless
ip route 192.168.95.0 255.255.255.0 192.168.90.2
ip flow-export version 9
access-list 1 permit 0.0.0.1 255.255.255.0
no cdp run
end
Router 2 configuration
hostname R2
ip dhcp excluded-address 192.168.5.1 192.168.5.20
ip dhcp excluded-address 192.168.90.1 192.168.90.3
ip dhcp pool Voip
network 192.168.5.0 255.255.255.0
default-router 192.168.5.1
option 150 ip 192.168.5.1
ip dhcp pool Wifi
network 192.168.88.0 255.255.255.0
default-router 192.168.88.1
no ip cef
no ipv6 cef
spanning-tree vlan 5,10,15,20,30,40,50,88,99 priority 4096
ip address 192.168.95.1 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet0/0.5
encapsulation dot1Q 5
ip address 192.168.5.1 255.255.255.0
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.15
encapsulation dot1Q 15
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface FastEthernet0/0.40
encapsulation dot1Q 40
ip address 192.168.40.1 255.255.255.0
interface FastEthernet0/0.50
encapsulation dot1Q 50
ip address 192.168.50.1 255.255.255.0
interface FastEthernet0/0.88
encapsulation dot1Q 88
ip address 192.168.88.1 255.255.255.0
interface FastEthernet0/0.99
encapsulation dot1Q 99 native
ip address 192.168.99.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
no ip address
clock rate 2000000
shutdown
ip address 192.168.90.2 255.255.255.0
ip nat inside
interface Vlan1
no ip address
shutdown
router rip
network 192.168.95.0
ip classless
ip route 192.168.15.0 255.255.255.0 192.168.90.1
no cdp run
end
Multilayer Switch configuration
hostname MS1
ip dhcp pool CustomerAndService
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip dhcp pool Finance
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip dhcp pool HR
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
ip dhcp pool ITSupport
network 192.168.40.0 255.255.255.0
default-router 192.168.40.1
ip dhcp pool Admin
network 192.168.50.0 255.255.255.0
default-router 192.168.50.1
ip routing
switchport trunk native vlan 99
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 000b.be52.2501
interface Vlan15
mac-address 000b.be52.2502
interface Vlan20
mac-address 000b.be52.2503
ip access-group 1 in
ip access-group 1 out
interface Vlan30
mac-address 000b.be52.2504
interface Vlan40
mac-address 000b.be52.2505
interface Vlan50
mac-address 000b.be52.2506
interface Vlan90
mac-address 000b.be52.2507
interface Vlan95
mac-address 000b.be52.2508
interface Vlan99
mac-address 000b.be52.2509
router rip
ip classless
ip route 192.168.15.0 255.255.255.0 192.168.90.2
end
There are numerous problems with your configuration. Vlan 15 on the Multilayer switch as network 192.168.15.0 configured, the same network exists on Router 0. Change your addressing so that it does not overlap.
Also, Vlan 99 on the Multilayer switch has the same IP address as the connecting interface on Router 1, 192.168.99.1. Change that duplicate address as well...
10 Replies 10
Julio E. Moisa
It looks like a routing problem, have you verified if each layer 3 devices have the destination networks into their routing tables? including the networks used to interconnect each device.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Georg Pauwen
in addition to Julio's post, upload the Packet Tracer file (zip it first to upload), that makes it easier to troubleshoot...
ok
Which of the PCs cannot reach Server 0 ?
all of the PC, Multilayer switch, and Router 2
Also, on R1 you have IP nat inside and outside interfaces configured, but there is nothing configured to be NATted.
What are the requirements for this network ? Is this a lab ?
yes, it's a lab. The requirements is all devices can ping each other, the configure I was done, just the device can't to ping, so I need to troubleshoot it. Thanks for your reply
the main problem is that you are using the same IP address space on different devices. Is this what the design is supposed to look like, and is the main purpose of the lab to use NAT ?
Hello
  • You have NAT enabled on RTR1 however at the same time you trying to advertise all networks to each other so why do you need NAT?
  • you have ripv1 enabled on the rtr1-2 and the switch with auto summerisation enabled and as ripv1 is classful it will only advertise prefixes that match the subnet mask of its interface thats one reason why you routing isnt working correctly
  • rtr2 AND the switch are performing intervlan routing not needed on both devices- plus you have duplicate addressing
  • You have nat enabled on rtr1 and rtr2 but looking at your topology rtr and the switch are outside of rtr1 and the server, so just have nat on rtr1 for the server
Try the following for a NAT solution from rtr1
rtr1
no router rip
no ip nat inside source static 192.168.15.1 192.168.90.1
no ip route 192.168.95.0 255.255.255.0 192.168.90.2
no ip default-gateway 192.168.99.1
no access-list 1 permit 0.0.0.1 255.255.255.0
access-list 1 deny  host 192.168.15.2
access-list 1 permit 192.168.15.0
ip nat inside source static tcp 192.168.15.2 80 192.168.90.1 80
ip nat inside source list 1 interface Serial0/3/0
ip route 0.0.0.0 0.0.0.0 192.168.90.2
rtr2
no ip nat outside
no ip route 192.168.15.0 255.255.255.0 192.168.90.1
no int fa0/0.5
no int fa0/0.10
no int fa0/0.15
no int fa0/0.20
no int fa0/0.30
no int fa0/0.40
no int fa0/0.50
no int fa0/0.88
no int fa0/0.99
defa int fa0/0
int fa0/0
ip address 192.168.95.2 255.255.255.0
no router rip
router rip
passive interface default
no passive interface fa0/0
ver 2
no auto
Switch
no ip route 192.168.15.0 255.255.255.0 192.168.90.2
no interface Vlan90
interface Vlan20
no ip access-group 1 in
noip access-group 1 out
int vlan 5
no router rip
router rip
no passive interface vlan 95
ver 2
no auto
network 0.0.0.0
res
Paul
Kind Regards
Paul
