Need urgent help on ip device tracking max command
neeraj.a.verma
Hi ,
I need urgent help, I have installed 30  3650 devices in client location
I want to run ip device tracking max 0 command on cisco 3650 switches but I think its not supported , if any one can suggest if any alternate for this command which we can run on 3650 Switches
7 Replies 7
Philip D'Ath
Are you wanting to disable device tracking?
Yes I want to disable ,
Thanks a lot for your help
Hi Phlip ,
This command also not supporting on 3650-FQM  at interface level - software verion 16.3.3, please suggest
I would not run 16.x code unless you really have to.  It is very new.  I would stick to the more mature 3.7 or 3.6 train.
He doesn't have a choice, Philip.  FQM requires a minimum of 16.3.1.
Bad luck, I guess.
Philip D'Ath
If you want to disable it I think the command is something like "nmsp attachment suppress".  I think this might have to be applied at the interface level.
Leo Laohoo
IP Device Tracking needs to be enabled globally and at the interface level.
The minimum lines of configuration needed are the following:
  1. Globaly:  ip device tracking
  2. Interface-level:  ip device tracking max <ANY NUMBER HIGHER THAN 0>
To disable IP Device Tracking, use the global command "no ip device tracking" and remove the interface-level command.
