Nat translation not working
OneOpAfghan
Community Member
Nat translation box shows up empty
here are my commands
hostname IAR
no ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX15241M7O-
no ip domain-lookup
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
ip address 192.168.78.189 255.255.255.252
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 192.168.78.182 255.255.255.252
ip nat inside
interface Serial0/0/1
ip address 192.168.78.170 255.255.255.252
ip access-group 105 in
ip nat inside
clock rate 128000
IAR#
IAR#sh run
Building configuration...
Current configuration : 1844 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname IAR
no ip cef
no ipv6 cef
no ip domain-lookup
no ip address
duplex auto
speed auto
shutdown
ip nat inside
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip nat inside
ip nat inside
clock rate 128000
interface Serial0/1/0
ip address 192.168.78.174 255.255.255.252
ip nat inside
interface Serial0/1/1
ip address 209.165.200.225 255.255.255.248
ip nat outside
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 192.168.78.168 0.0.0.3 area 0
network 192.168.78.172 0.0.0.3 area 0
network 192.168.78.180 0.0.0.3 area 0
network 192.168.78.188 0.0.0.3 area 0
network 209.165.200.224 0.0.0.7 area 0
default-information originate
ip nat pool NATPOOLIAR 209.168.200.224 209.168.200.224 netmask 255.255.255.248
ip nat inside source list NATACL pool NATPOOLIAR overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1/1
ip flow-export version 9
ip access-list extended NATACL
permit ip 209.168.200.224 0.0.0.7 any
permit ip 192.168.78.0 0.0.0.255 any
access-list 100 deny tcp host 192.168.78.169 host 192.168.78.190 eq www
access-list 105 deny tcp host 192.168.78.181 host 192.168.78.190 eq www
access-list 105 permit ip any any
line con 0
line aux 0
line vty 0 4
login
end
5 Replies 5
Change this:
To this
ip access-list standard  NATACL
You dont need to put the outside address into the nat acl.
Georg Pauwen
the router configs look odd, why are you using /30 IP addresses on the inside interfaces ? Also, the IP address used for the NAT pool is included in the NAT access list. What are you trying to accomplish ?
Apparently the serial interfaces must be /30 and the 209.168.200.224 must be put in.
the inside interfaces are /30 too, what is connected to these interfaces, a single host ?
ip nat pool NATPOOLIAR 209.165.200.225  net mask 255.255.255.248 <- since you use this ip for outside nat interface
ip nat outside
