NAT U-Turn does not work on 2911 router
Ahmed Abdullahi
Consider this scenario:
  • 1. Both Host A 192.168.1.70 and Host B 192.168.1.70 have Router A 192.168.1.1 as the default gateway
  • 2. The network 192.168.1.0 /24 is NAT ‘d to the address 10.10.10.10
  • 3. There is a static NAT (port forwarding) for port 80 on IP 10.10.10.10 to 192.168.1.30
  • 4. Host A 192.168.1.70 ties to access web-server Host B by going to port 80 on 10.10.10.10
The connection fails. Is there any method to make this work?
AA
The config on the router is:
interface GigabitEthernet0/0
ip nat inside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
interface GigabitEthernet0/1
ip address 10.10.10.10 255.255.255.0
ip nat outside
ip nat inside source route-map nonat interface GigabitEthernet0/1 overload
route-map nonat permit 10
match ip address 110
access-list 10 permit 0.0.0.0 255.255.255.0
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source static tcp 192.168.1.30 80 10.10.10.10 80 extendable
0 Replies 0
