NAT / VRF with Switch Vlan topology
Hello all,
I've got to make work a VRF-lite /NAT with some vlan topology (I use GNS3 for create the network ).
We have got 2 router R1 and R2 (891f replaced with 3725 images) and an etherswitch R3 (3750 replaced with a 3725 image too).
16 Pcs with the same IP address (10.0.0.1/24) should have access the Pc download and also in reverse way, he could access them from his address 172.16.0.1 /24.
I need some advice for the configuration, because i get stuck for the sharing vrf route and also make vrf work with vlans (not present in config file).
I've been digging through all kinds of white pages, tutorial since few days to make this work.
Thanks in advance for the help
Jean-Marc
PS: config file and topology in the attachements
0 Replies 0
