01-07-2016 06:02 AM - edited 03-08-2019 03:19 AM
Hello forum Guys,
I just wonder do you know any cisco switch models that could be capable of transfering layer 2 Sync E packets ?
Solved! Go to Solution.
01-08-2016 04:38 AM
Also see the ASR1000 routers - they support Sync-Eth too
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asrswcfg/SyncE.html
Alex
01-07-2016 09:46 PM
This is the manual entry from a Cisco 7600 showing how to configure it. 7600's are being replaced by ASR 9k's.
The newer ASR 9k's look they also support it (search for 1588).
01-08-2016 04:08 AM
hello dath
thanks! 7600 or ASR9000 - those are expensive machines. I probably won't use 80% of its features. Do you know any other/cheaper alternative?
01-08-2016 04:38 AM
Alex
02-22-2016 03:59 AM
Just for somebody who would be interested in this topis - I also found Cisco ME-3600X-24CX-M Ethernet/TDM Access Switch which support sync E.
