NAT with Backup Interface on 871
feliciogs
I had a 871 between a LAN and two networks one Outside and another "inside" (different sub-net) LAN provided by an outdoor wireless device.
I need to NAT inside LAN to Outside while the outdoor wireless stay up, but if the wireless goes down I need to NAT a specific "inside" address to make transparent to clients the change. As in the draft below I need when the Desktop (10.5.1.111) try to connect to Server (10.1.1.239) during a Wireless fail the Server address (10.1.1.239) be "NATTED" to 172.16.1.1. The Desktop default gateway is the 871.
I'm trying to detect wireless down creating an additional VLAN interface as backup interface for VLAN1.
I was able to NAT the Outside network and route packets while inside network is connected to VLAN1, but when I connect the inside network to VLAN2 I start to lost packets.
Anyone has any idea what I'm doing wrong ? My objective is reachable ?
A draft of my connections (copy&paste to notepad w/ "Fixesys" font to see correct ident):
.........................* Desktop *
.........................(10.5.1.111)
(10.5.1.253).............(Unnumbered)
*** 871 ***..............* Wireless *
(172.16.5.253)...........** Bridge **
(172.16.5.1).................\ /
*WAN Cloud*...................|
(172.16.1.5)................./ \
(172.16.1.1)............* Wireless *
*** NAT ***.............** Bridge **
(10.1.1.3)..............(Unnumbered)
.....|..................(10.5.1.254)
.....|..................*L3 Switch*
.....|..................(10.1.1.254)
.............Server
..........(10.1.1.239)
What I had done at 871:
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
switchport access vlan 2
interface FastEthernet3
interface FastEthernet4
ip address 172.16.5.253 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
backup delay 10 30
backup interface Vlan2
ip address 10.5.1.253 255.255.255.0
ip nat inside
no ip virtual-reassembly
ip tcp adjust-mss 1452
interface Vlan2
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Vlan1 10.5.1.254
ip route 0.0.0.0 0.0.0.0 Vlan2 172.16.5.1 250
ip route 172.16.1.0 255.255.255.240 FastEthernet4 172.16.5.1
ip nat pool IPVPN_UN05 172.16.5.2 172.16.5.252 prefix-length 24 type match-host
ip nat inside source list 100 pool IPVPN_UN05
access-list 100 permit ip 10.5.0.0 0.0.255.255 172.16.0.0 0.0.255.255
no cdp run
TIA,
Felicio Santos
tstanik
Level 5
Level 5
Here is the URL for the NAT Support for Multiple Pools Using Route Maps guide with configuration which will help you :
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml
